hotpoint wt400
  • #48565
    donnyscuba
    Hi, i have a hotpoint wt400 toploader which has stopped working after tripping curcuit breaker. now it fills, and then flashes door locked led quickly and another led. any clues?
    dg
    #296974
    Re: hotpoint wt400
    By number, which “other LED”?
    donnyscuba
    Re: hotpoint wt400
    from the top, out of four leds, its number four, marked spin.
    dg
    #296976
    donnyscuba
    Re: hotpoint wt400
    still no luck with this one, any clues???
    #296977
    twinspark
    Re: hotpoint wt400
    motor faulty i think
    #296978
    Re: hotpoint wt400
    No – fault codes on this appliance are indicated by the power lamp flashing in a pattern; ie 1-2-3-4-pause-repeat. The selector will also be clunking round.
    In this instance, I would suspect that the pcb is damaged, due to whatever component short circuited – the OP will have to identify that component first. Lid lock, motor and heater are primary suspects.
