Re: Hotpoint WT540
Hi, Rob!!
Check the connection plugs and crimp them up tight on the mainboard (back of the machine at the bottom.) Also tighten the fascia supply plug.
If that fails, it’s the main PCB that’s goosed.
EMW do the boards already set up to plug ‘ n ‘ play. You will need the model number (WT540) and the letters off the end of the PCB board – ICTFT is the Mk 4 PCB and ICTFCT is the Mk 8 PCB. Probably Mk 4 TBH. 😉
Hope that helps,
Steve.
