Hotpoint WT540
  • #61446
    ranharris23
    I have a Hotpoint WT540 when i close the door the door locks but the indication light to say the door is lock doesn’t come on. It also doesn’t take in any water. All that happens is the wash light comes on
    and the machine will not do antthing else.
    #346165
    Specialist01269
    Re: Hotpoint WT540
    What Happened to your Indesit?
    #346166
    johnnyj
    Re: Hotpoint WT540
    Try looking in the direction of the motor???????????????
    #346167
    ranharris23
    Re: Hotpoint WT540
    The Indesit is working fine
    #346168
    ranharris23
    Re: Hotpoint WT540
    I checked the motor brushes they are fine
    Whatever I select the door lock light never comes on even though the door locks .
    it will not pump water out
    it will not take water in
    the drum will not turn
    #346169
    Specialist01269
    Re: Hotpoint WT540
    Glad to hear it, what was the colour code on the valves after?
    On the WT540, check the motor connector is seated properly, check motor brushes, check for breaks in the motor harness.
    #346170
    Re: Hotpoint WT540
    Are you in the trade ranharris23?
    #346171
    ranharris23
    Re: Hotpoint WT540
    I am an electrician by trade
    Myself and a few frends run a l scrap yard. we try to repair the appainaces that come to us.
    Then we sell them to local second hand shops.
    So yes we are trading
    #346172
    ranharris23
    Re: Hotpoint WT540
    Specialist01269 wrote:Glad to hear it, what was the colour code on the valves after?
    I checked all of that i think the main PCB in down.
    #346173
    Re: Hotpoint WT540
    ranharris23 wrote:I am an electrician by trade
    I do hope that you have acquainted yourself with all of the current legislation with regard to the WEEE directives. 😉
