My partner has removed the old element, and has put the new one in but it fouls on the drum – when the drum turns it rubs on the element and pushes element out of slot, element is same size as original – any ideas!!
Re: hotpoint wt540 -changing element but now banging against
Did the new heater element come with the tin bracket attached? If it didn’t you will need to transfer the one off the old element by straightening / bending the tags. The end of the tin bracket locates in a slot formed in the tub moulding.
hi Phidom,
The new one had a tin bracket on it, but the old one didn’t so he took off the bracket on the new one – do you think the old one is stuck in the machine – is this possible?
hi
found teh old bracket, and have removed it, unfortunatley I took off the bracket off teh new one and can’t remember which way round it goes, wehn inserting the heater element should the bracket be ABOVE the element of below the element?
Thanks – we have it all fixed and it has just completed its first load – thanks to you all SO much for your time and patience, this weekend this forum has helped me repair 2 appliances – THANK YOU!!!!
