Hotpoint WT540 Fault. Overfilling & Prewash Flashing, 12
Home Forums Public Support Forums Help And Support Washing Machine Help Forum Hotpoint WT540 Fault. Overfilling & Prewash Flashing, 12
  • #25842
    moscow
    I have a Hotpoint WT540 Washer.
    It is Just, Just over 12 Mths old.
    Suddenly started overfilling to the point of water coming out of Powder Compartment when running and Prewash Light Flashes.
    Any info would be greatly appreciated!
    Moscow
    #207803
    Del
    Re: Hotpoint WT540 Fault. Overfilling & Prewash Flashing
    Sounds like a pressure hose problem. Do you do a regular maintinance wash in your machine as this helps to prevent the problem.
    Del
    #207804
    At this age I would suspect a blockage in the sump filter first.
    Ritch
    Hi are you sure that the drum is filing right up and then out of the draw or could it be possible that its just pouring out of the draw and not even making it to the drum? as i have had socks get stuck between the drum and outer tub that work there way up to the hose between the tub and despenser draw?
    #207806
    moscow
    Thanks for the tips.
    I don’t think its anything to do with the drain as it overfills as soon as switched on before drainage is needed.
    It fills about halfway up the drum and then when running it splashes out of the powder draw.
    Could this be the level sensor.
    Cheers
    Moscow
    #207807
    moscow wrote:Thanks for the tips.
    Cheers
    Moscow
    I refer the Honorable gentleman to my first post, the pressure chamber for the water level switch is combined with the sump hose where you will find most blockages. 😉
    moscow
    Cheers Jim
    I’ll give that a look and get back to you.
    #207809
    moscow
    Hi Jim
    Just checked your recommendations.
    The Filters are really Clean and there is no blockage.
    Still doing the same.
    When I put machine on pump out it empies as fast as always has.
    Any other ideas.
    #207810
    The pressure switch itself is not prone to failure, at least not as much as the main control PCB which can also cause this fault. It may be time to take advantage of your five year parts warranty, prewash light flashing can be caused by a faulty fill valve but that usually prevents the machine from filling. Tiny holes chafed in the thin plastic hose to the pressure switch can also cause this but again not common on this model. It really is getting to the ‘get someone in’ time I’m afraid.
    moscow
    Cheers Jim.
    Good News
    I have restripped the filters and found nothing wrong or blocked. Blew the tube to the pressure sensor.
    Now working fine!
    Thanx Guys for all the info!
    Moscow
    #207812
    tyler
    it will definatley be pcb and eprom,prone to damp and static it will require both and then eprom will have to be wrote but can only be done by us hotpoint eng.
    #207813
    bigkid
    “then eprom will have to be wrote but can only be done by us hotpoint eng.”
    Realy?
    :rotl:
