After a bit of advice guys,
I put awash load on and half way thru the cycle it stopped and light 2 started flashing. I checked the screw in filter thing bottom right and recovered 2 1p’s from it restarted cycle and same thing happened again. I drained the machine ia the filter (bottom right) and managed to get the clothes out. one of the times i simply tried unpluggin it and leaving for 10 mins the lights 2 & 4 came on, this only happened the once.
so what i am after is what does the light 2 error code relate to, and hopefully if it fixable by myself and mucho cheapness 😛
thanking you in advance
