hotpoint wt540 – help just keeps washing!!
Home Forums Public Support Forums Help And Support Washing Machine Help Forum hotpoint wt540 – help just keeps washing!!
  • #37544
    broadpaws
    Hello,
    My machine is just over 2 years old, and yesterday it just keeps on a washing! Basically it will not go to the rinse and spin stage. I let it wash then I have to turn it off, then move the dial to rinse and spin – which it will then do.
    I have checked the filter at the front, there were a couple of buttons and coins there, cleared the coins etc and then the same problem.
    Any help appreciated
    BP
    #255497
    nigegt
    Re: hotpoint wt540 – help just keeps washing!!
    Probably just the heater has failed not a big problem, see spares@ for a diy part or repairs@ for a repairer near you.
    Cheers
    Nige
    #255498
    broadpaws
    hello Nige,
    Think you are right as on a cold wash its just completed the cycle, I have looked at the spare part bit on this board, do you know is it an easy job or is an engineer better?
    BP
    #255499
    In theory, simple – undo one nut and pull. It’s usually a right wrestling match, though.
    THIS is the one that you want.
    Power off first……….
    broadpaws
    hello Penguin,
    Thanks – when you say one bolt, do I have t take the back off the washing machine, and will I see the element straight away?
    Sorry for my ignorance 😳
    #255501
    Yup, 6 o’clock on the back of the tub.
    broadpaws
    Thank you, element ordered will let you know how I get on!
    BP 😆
    #255503
    broadpaws
    hi penguin,
    the element has arrived – do I have to remove the whole of the back which includes a large metal strip across the centre of the back and does that mean that the water pipe has to come off and do I need to removethe screws that hold the top?
    Sorry 😳
    #255504
    hotpnt
    just the access panel at the bottom of the back
    #255505
    broadpaws
    Thank you thank you!!
