F01….OFF, OFF, OFF, Flash, OFF
is a motor triac fault
usually that means the boards gone
BUT
it could be a broken wire in the motor harness and/or board plug?
experience would suggest a pcb problem, to which u need a new smart card and reader, thats subject of course to whether it has a ceset motor or an fhp motor
confused? oh you will be… just look around the forums, its littered with many weary tales of unereliable indesit electronics
and if your going to look, make sure u unplug the machine for 5 minutes before you go in
thank you, hope this helps?
