Hotpoint WT721 F08 error code
Home Forums Public Support Forums Help And Support Washing Machine Help Forum Hotpoint WT721 F08 error code
  • #82387
    spannerman43
    Hi All,
    I have a Hotpoint WT721 that is displaying F08, all lights were flashing it started to wash and now flashes F08.
    Help!!1 have a young family and mountain of clothes to wash, would rather repair it that just dump it and buy a new machine. I am very competent with a multimeter.
    Kind regards
    Andy :mrgreen:
    #419692
    Re: Hotpoint WT721 F08 error code
    F08 : Oh dear, bad news, heater related fault. Could be a faulty heater, thermistor, duff control board, bad connection, wrong time of the month or a sudden change in wind direction. I kid you not F08 is a difficult fix and I wish you well solving it from the clues I gave. :tup:
    #419693
    spannerman43
    Hi Martin,
    OK thank you, so with heater could it just be O/C? Is the thermistor on the heater? like a plug in unit? Connections I can check no problem. I had heard someone say it could be worn brushes? I guess thats not true?
    With control PCB are they just plug and play or do they need to be programmed?
    Kind regards
    Andy
    #419694
    spannerman43 wrote:so with heater could it just be O/C?
    Could be.
    spannerman43 wrote:Is the thermistor on the heater?
    Yes
    spannerman43 wrote:like a plug in unit?
    Yes
    spannerman43 wrote:I had heard someone say it could be worn brushes? I guess thats not true?
    Not true
    spannerman43 wrote:With control PCB are they just plug and play or do they need to be programmed?
    The latter
    #419695
    spannerman43
    Ok, Can I test the thermistor? I was thinking if I use a multimeter on the two terminals and put the thermistor in cup of hot water the resistance should change? indicating it is OK? Or are they more complex or a better way to test?
    #419696
    You are correct, the resistance across those terminals (measured in Kohms) will change as the temperature fluctuates up or down. 😀
