Hotpoint WT721 Strange F-08 fault
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Hotpoint WT721 Strange F-08 fault
  • #88045
    myfil
    I went to a Hotpoint WT721 Washer as the customer was reporting an F-08 fault halting the machine. As we know this is usually heater or heater relay on the board.
    I put the machine onto a spin (to check if motor and pump were ok) and it pumped, turned slowly (distibution) for a while, the stopped with F-08. Then nothing worked to remove the flashing fault code, short of actually unplugging the machine.
    As the heater circuit was not called into action at all, I find this puzzling. Does F-08 indicate anything else other than heater and heater relay?
    Thanks for help.
    #436832
    Re: Hotpoint WT721 Strange F-08 fault
    The electronics will self test and throw up an error code for heater faults even when set to spin.
