hotpoint wt740
  • #58033
    suedehead1
    hi, its the hotpoint with the digital display it keeps flashing up H2O
    it fills ok, nothing in sump pressure switch hose ok,
    but somewhere in the program it flashes H20
    any ideas please?
    #333167
    Re: hotpoint wt740
    go to search and type H20 you would have found this
    HERE
    suedehead1
    Re: hotpoint wt740
    i had already searched H2O and it said not filling pressure switch tube, syphoning all checked and ok.
    #333169
    Re: hotpoint wt740
    iadom wrote
    As you have realised H20 is some clever clogs programmers idea of a subtle hint., ie, H20 as in water. It does mean that the machine has ‘timed out’ on fill. If the valves themselves are faulty then you should get a different error code. Do you have a poor water pressure or ‘dirty’ mains water? Have you removed the fill hoses and put them into a bucket and turned the taps on, sometimes the modern poorer quality plastic Red & Blue taps can appear to be turned on when in reality it is only the plastic that is turning and not the tap.
    hope this helps
    suedehead1
    Re: hotpoint wt740
    hi thanks for the replies the water pressure is goodit seems to show H20 nearer the end of the program i am thinking maybe the conditioner valve is faulty
    #333171
    suedehead1
    Re: hotpoint wt740
    a solenoid on the water valve was faulty, it worked for a bit then went open circuit, replaced it and i am keeping my fingers crossed.
    thanks everybody.
