Hotpoint WT761
  • #33963
    Question for the Hotpoint lads.
    Went to this 13 month old machine today, complaint of display going back to 13 minutes.
    Set it to drain and display showed 2 minutes it then progressed to END without any problems.
    Set to short spin, display shows 13 minutes, goes through a very short spin, then stops, timer counts down a few minutes then at 5 minutes on display it starts filling, it empties out and fills again, advances to the 1 minute display then reverts back to 13 minutes and starts all over again. 😥
    I have referred customer back to Hotpoint, I assume the PCB or Eeprom is goosed. Would you be able to clear this just by re writing the eeprom or would it definitely need a new PCB.
    Is likely to be the main PCB or the console module?
    kiddo66
    Re: Hotpoint WT761
    More than likely the power board,cant see rewriting eeprom doing much good.I take it that there were no earth leaks?
    #240699
    Re: Hotpoint WT761
    Didn’t get that far TBH, was severely pushed for time and the installation would have meant half an hour getting it out.
    As a percentage, how often do you get away with an eeprom rewrite?
    johnnyj
    Re: Hotpoint WT761
    Faults like this sometimes clear with a rewrite, problem is most engineers are shit scared to try it for the fear of a recall or the dreaded 3 day recall, they will lob in a module and eeprom every time i usualy try ones like that with a rewrite and it usualy cures most of the time.
    #240701
    kiddo66
    Re: Hotpoint WT761
    I usually try rewrite,you can get some queer motor faults that will clear up with a new file downloaded.I would say about 10{e5d1b7155a01ef1f3b9c9968eaba33524ee81600d00d4be2b4d93ac2e58cec2d} are succesfull with just a new eeprom file.
    #240702
    Re: Hotpoint WT761
    Thanks for your replies . 8)
