hotpoint wt761 bearing replacement
Home Forums Public Support Forums Help And Support Washing Machine Help Forum hotpoint wt761 bearing replacement
  • #79875
    stumac27
    Currently replacing the bearings on my hotpoint ultima, stripped out drum etc without any issues or difficulty but finding the shaft wont budge from the bearing housing despite a good few rattles with a hammer.
    currently have the drum sitting open end to floor and shaft at top whilst both parts are together. not sure if sitting rear half on supports would help but the plastic seems flimsy when not sitting over front half
    any tips appreciated as it seems an easy fix otherwise.
    regards
    Stuart
    #410907
    Re: hotpoint wt761 bearing replacement
    Stand it upright with the shaft vertical. Soak the shaft with WD40 and leave it overnight in the hope the WD40 soaks down to the rusted front bearing. Then turn the drum sideways and get heavy with the hammer in the hope you whack them apart.
    #410908
    stumac27
    went for the wd40 after typing this, im guessing its seized to the shaft which will be annoying if i cant free it
    #410909
    A12hour soaking of WD40 could make the task easier. Also swearing at it, in Italian of course, whilst thumping it with a hammer helps! 😉
    #410910
    You must split the outer drum before you make any attempt to remove inner drum.
    #410911
    stumac27
    Outer drum has been split and is housed together loose
    #410912
    Well don’t start wielding the hammer until the front tub half has been removed for goodness sake !!!
    #410913
    stumac27
    well it took a fair pounding to shift it, now cant remove the outer bearing after knocking the center out of it, oh joy!!
    #410914
    stumac27 wrote:well it took a fair pounding to shift it, now cant remove the outer bearing after knocking the center out of it, oh joy!!
    More joy awaits you when you discover the state of the drum support shaft and realise that needs replacing too! 🙁
    #410915
    stumac27
    Both appear fine but doubt im going to get the remainder of the bearing out so may have been a waste of time lol
    #410916
    Oh? A bit of improv and a cold chisel helps. 😉
    A bit of the Evren Yurtsen spirit needed methinks. 💡
    #410917
    stumac27
    Lol pressure from the wife means fixed tomoz or new one thursday lol
    #410918
    gandh1
    4mm h/s/s drill bit, start from halfway and guage 3 (tri) or 4 (quad) grooves down inwards to inside of bearing housing in tub, and then cold chisel (edge in grooves) the remaining edge of the bearing race with no less than an 8lb sledge hammer. you will get it out, after about 20 mins. just be sure your grooves arent too deep they extend past the outside edge of the bearing, otherwise the obvious water ingress will happen. it is a bit of a bodge but its the quickest way, HTH
    #410919
    stumac27
    Drill wouldnt look at it so modified a screwdriver by bending the end to a curve and again giving a good few skelps. Now to add the bearings which seem much tighter than those in the allparts videos lol
