Hotpoint WT761 G Bearings
  • #58742
    Madmac
    The bearings need replaced in this 7kg machine, the drum is a split type but not sure if it uses the standard 30/35mm types?
    Anyone know?
    Thanks,
    Eddie.
    #335505
    snig
    Re: Hotpoint WT761 G Bearings
    If its 30mm it will say so on the tub rear half behind the pulley. can be difficult to see with tub in situ.
    #335506
    Allsorts
    I did one the other day… 35mm bearings in the one I had.. The drum is different than the 6kg though.
    George
    #335507
    35 mm on these, drum rear half is a C00144137.
    #335508
    Madmac
    Cheers chaps, minimal play as she stopped it quickly so hope to get away with bearings alone. Did think these induction motor machines would leave us stuck for repair work but in the 4 years shes owned it I’ve replaced the door handle, the heater, a mouldy door seal and now the bearings next week..happy days! 8)
