hotpoint wt761g no spin
  • #48287
    gramp
    hotpoint wt761g ser no.63270007
    wont spin just tumbles thru whole spin cycle . motor makes a noise every min. as if it was trying to do something
    no fault codes this is a brushless motor
    #296181
    helo_75
    have you ran it empty?
    #296182
    gramp
    Re: hotpoint wt761g no spin
    yes tried it with nothing
    pumps fine just no increase in speed at any part of spin cycle
    #296183
    Might be a problem with the pressure switch or associated parts. This is a round device mounted near the top of the machine with a thin hose going to a pressure vessel. You could try pulling this hose off the switch and running a spin like that. Remember to refit the hose after this check and make sure the plug is out when delving into the innards of the machine. If it spins OK with the hose removed you have a choked pressure vessel or blocked pressure hose.
