Hotpoint wt960
  • #83523
    Patch40
    I have a hotpoint wt960 it fills with water, the time elapses the front screen states ‘wash’ but nothing turns or moves. It then sits at 1minute for ever, until I press cancel when it pumps out and Ends.
    The belt appears intact, the pump seems to be working what could the problem be my guess is either motor or electronics all help greatly welcome
    P
    #422974
    Allsorts
    Re: Hotpoint wt960
    The problem is most likely to be either connection of the motor cable to the PC Board or a fault with the board itself…
    If you are going to check, make sure to leave at least 10 mins before touching the board after disconnection as they can hold charge
    #422975
    Patch40
    Re: Hotpoint wt960
    Thanks for you reply
    I’ve pushed all connectors I can see including the one with the five red wires that connect to the board, and no joy, is there a specific wire connector i should be looking for?
    P
    #422976
    Allsorts
    Re: Hotpoint wt960
    I would suggest then you send the board to EWM Electronics for testing / repair
    #422977
    Patch40
    Re: Hotpoint wt960
    I’ve tested the suspect board by installing it on a working machine, the board seems fine the drum turns etc. any other suggestions as to what I should check next?
    P
    #422978
    Re: Hotpoint wt960
    The motor.
