Hotpoint WT960 Dead
  • #61380
    Bernie
    Hotpoint WT960 Dead
    Fitted replacement board from EMW machine ok for 5days then got call back same fault sent board back to EMW no fault found with board power to machine, live & neutral to board.
    Anyone know what else it might be going back to fit returned board on Wednesday 2nd
    Thanks Bernie
    #345898
    HotDog
    Re: Hotpoint WT960 Dead
    console mod will prob gone get emw to test
    #345899
    helo_75
    there was a memo about this exact problem
    check the pins in the plug to the fascia pcb
    its not uncommon
    #345900
    Bernie
    Thanks for the quick reply
    Bernie
    #345901
    Bernie
    Was that all the memo said or was there more helo_75
    Thanks Bernie
    #345902
    Bernie
    Helo_75 Could you let me know if there was more in the memo as I am still having problems with this one?
    I fitted the returned board checked the pins in the plug to the fascia and main pcb tested them for continuity all ok, put it on a spin to test worked for 3/4 mins cancelled program was going to put it on a wash when the front facia display started to flash then went blank machine dead. Sent both facia and main modules to EMW for testing, Tony could not find anything wrong.
    Going back next week any help please.
    Bernie
    #345903
    Being as Tony has tested both boards for you and that they worked OK initially until you cancelled the spin cycle. It does point toward there being a connection problem between the 2 boards.
    It might be best to fit a new harness link between the two?(PartNo C00113957) 💡
    #345904
    Bernie
    Thanks for that Martin, it’s the only thing I can think of trying too.
    Bernie
    #345905
    What about a dodgy interference filter at the mains inlet?
    Mike.
    #345906
    Bernie
    Thanks Mike will give that a look too, have orderd new Harness that goes between the two boards.
    Bernie
    #345907
    Have just returned from looking at a WT960. Report was blew fuse, fuse replaced, completed wash. Subsequently blew trip, restored power, completed wash. Then blew trip again mid-wash, now totally dead.
    Got there, meggered it, found heater down. Disconnected heater. Restored power. Display came up and would programme fine but as soon as start was pressed, display went out and everything dead again. (All took a bit longer than it sounds because of cramped space, short hose, dodgy lino etc.)
    Did not remember this discussion, so did not look at fascia plug. Just told her to call Hotpoint (still doing £99 deal?) as I didn’t want all the faffing around with the fancy electronics and then have repair cost soaring anyway.
    Now wondering if I did the right thing.
    Mike.
