Hotpoint WT960 error code f08?
Home Forums Public Support Forums Help And Support Washing Machine Help Forum Hotpoint WT960 error code f08?
  • #48155
    HayleyA
    Please can anyone tell me what error code f08 means on a Hotpoint WT960 washing machine?
    The code appears after a full wash cycle has completed, the clothes appear to have washed ok and the washer has rinsed and spun them just fine. If I turn the machine off then on again it disappears and I can select a program as normal.
    Will I need to get an engineer out or is it something we can fix ourselves?
    Many thanks for any assistance,
    Hayley
    #295777
    Re: Hotpoint WT960 error code f08?
    Heater relay fault on pcb. Can be heater and wiring, but it’s usually the pcb.
    Power off if you intend to repair this yourself.
    HayleyA
    Thank you for replying, I guess I’ll get someone out to have a look at it, sounds a bit too much for us to attempt, don’t want to make it worse!
