hotpoint wt960 low water level
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries hotpoint wt960 low water level
  • #75289
    delta01
    hi just fitted an emw recon module, and the water level is very low
    giving poor wash results can this be the module?
    thanks john
    #394418
    Muv
    Re: hotpoint wt960 low water level
    Was this problem evident before of after you replaced the module?
    As it sounds like you just have a blockage in pressure vessel or faulty pressure switch
    delta01
    hi Martin not sure customer had not complained of poor perfomance, however the module was replaced as i returned the previous faulty one (which had no display) so this is a different one, i had thought of trying a p/switch and will do so but not confident that will cure it thanks john
