Hotpoint WT960 strange noise
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Hotpoint WT960 strange noise
  • #63659
    Weird one this.
    It fills up and starts to wash perfectly silently but after 20 to 30 minutes it makes a ‘knocking’ sound, but only when turning clockwise when viewed from front. This is when doing a wash action BTW.
    It sounded to be around the pulley area but having changed that it is still the same.
    Nothing loose that I can see, sus units appear OK. ❓
    Any suggestions?
    Re: Hotpoint WT960 strange noise
    Motor mounting?
    Mike.
    #354462
    I wondered about that but could see nothing amiss, strange why it only occurs after a period of time, only in one direction and only at wash speed though. :con:
    #354463
    What is the frequency of the knocking in beats per drum revolution :?:. Could even be a bearing. Is it a welded tub :rolls: ?
    Mike.
    #354464
    35mm bearing, 7kg split tub.
    I have only heard it once, just a steady click/knock noise at approx one second intervals.
    #354465
    Probably best to tell them to wait and call you again when/if it gets worse. ( I bet they’re not youngsters with three kids.) You probably won’t have more than a couple of months to wait. Or it could disappear as mysteriously as it arose. Just one more thought. Have seen bearing housing come loose in tub shell in an old model.
    Mike.
    #354466
    He is an old bloke who stands over you all the time, :rolls: going back tomorrow for another look.
    Seen many bearing housings loose in WM/WD models but never in WMA type drums, all of them caused most noise when on spin though.
    If it’s the bearing, there’ll be no way of knowing till you get it out. Had same on an old Servis once. That was an old git standing over me too.
    Mike.
    #354468
    Allsorts
    Something catching on the seam of the inner drum Jim?
    George
    #354469
    johnnyj
    Getting loads of 7kg machines with the bearings going, also had a few with loose back bearing had to fit back half to cure,
    #354470
    Bernie
    Did have something similar cannot remember what make, the chasse next to the one of the suspension legs had a two inch crack.
    Bernie
