Hotpoint WT960P 7KG
  • #47391
    squadman
    Got a motor which has the bearings collapsed and have found two motors listed at Connect :
    5045171498954 3 phase Motor & 5045170721312 which is listed as an Ariston motor, the machine I have is a 7KG version can someone confirm if the three phase motor is the correct one I need
    #293324
    Re: Hotpoint WT960P 7KG
    Masterpart list the motor as the 3 phase, C00144157. I would have thought the 3 phase sort would be identifiable by it’s lack of brushes 😕
    #293325
    squadman
    Thats a fair point my friend which I will confirm later when I see it !
    Thanks for the help
    #293326
    squadman
    Yup, Three Phase indeed, problem is that front bearing has become loose in motor casing causing excessive play and poling of motor F.02 Fault Code.
    Look like a new motor !
