Hotpoint…WT965A..ser.no. 606140041
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Hotpoint…WT965A..ser.no. 606140041
  • #30883
    robbra
    This machine tripped the electric and lost all display and is dead.
    There is power to the main board in the base but no visible blown components. I checked wiring for damage and meggered the motor and element.
    I don’t want to order the board if there could be another reason for the machine being dead or may need any other parts as well.
    Any advice welcome.
    Thanks.
    Rob
    #228755
    HotDog
    Re: Hotpoint…WT965A..ser.no. 606140041
    remove console module contacts and refit checking good connection common fault
    #228756
    robbra
    Hi Hotdog,
    I removed all the connections and refitted them but to no avail.
    I wondered if there could be anything else.
    Thanks,
    Rob
    #228757
    robbra wrote:Hi,
    It should be at least two pieces blowed on main PCB… if does not gives any signs of live at he tripped electric fuse. [ex.: near to motor triac radiator you should see one 20Ohms/2watts resistor(red,black,black marked) which is blowed, but don’t replace her because there are more and effects could be 👿 ….]
    Any advice welcome.
    Thanks.
    Rob
    Do you not have any other chance :rolls: … unless can you repair main PCB… 🙁
