Hotpoint’s not draining
Viewing 15 posts - 1 through 15 (of 15 total)
  • #73351
    Had three like this in past couple of weeks. Today it was an 18 month old WDL540.
    Pump and hoses all clear, set it to drain only and the pump runs for a couple of seconds then cuts out. No sign of an overload in these pumps but on all three machines I have plugged the connector into a brand new pump with exactly the same results.
    I am assuming that there is a pcb fault, unless you know better. 😉
    madangler1
    Re: Hotpoint’s not draining
    If its the linear pressure switch model then it won’t drain with out any water in it, Otherwise check the door lock, I have seen these cause a number of really strange problems on the Arcadia electronics, possibly motor as well. The module will not pump or do anything if either motor or door lock is playing up
    I had one last week doing something similar, door locked and light was on as it should be but it just would not do anything. After trying everything else tried the interlock
    Not seen many on these doing it though 3 is unusual.
    #387185
    Thanks, will look out for that next time.
    allan73
    Did you get to the bottom of this one Iadom ?
    I’ve got one of these with the same fault. Customer has removed a hair grip from the filter so I’m wondering if board damage has occurred.
    Allan
    #387187
    timdowning
    Not forgetting this thread either –
    post381547.html?hilit=arcadia#p381547
    #387188
    allan73
    Thanks Tim. I have tried to reset the pressure switch also, to no avail.
    Allan
    #387189
    I seem to remember johnnyj posting that on some occasions he has had to rewrite the eeprom.
    #387190
    allan73
    Thanks I’ll speak to the customer.
    Allan
    #387191
    A1engineer
    guys I’ve had this a few times on the washer dryers believe it or not its a faulty dryer ntc or ntc wiring 🙂
    don’t ask me why 🙂
    #387192
    allan73
    Would the NTC stop the pump from being energised ?
    The machine will fill, wash and spin when emptied manually.
    Allan
    #387193
    A1engineer
    when the ntc fault occurs the pump runs for about 2 seconds then cuts off, reset and try again it will again run for 2 seconds etc
    if you have a linear pressure switch or software issue then the pump wouldn’t run at all as the machine thinks its empty( even tho its not)
    #387194
    allan73
    Interesting…that’s exactly the problem, thanks A1 !
    Allan
    #387195
    hilly
    did you sort yours allan?
    ive got a indesit w/m and a hotpoint w/d with the same problem they will do the full spin but only drains for a few seconds.
    the hotpoint I disconnected everything apart from interlock, pressure switch and pump and it still did the same, but no error code
    cheers paul
    #387196
    allan73
    My problem was dryer NTC on washer dryer Paul. Had the same problem a few times since posting.
    Pump runs for a few seconds then cuts off, common fault it seems.
    Allan
    #387197
    hilly
    cheers allan
