hotpointwm64 pcb fault Home › Forums › Public Support Forums › Help And Support › Washing Machine Help Forum › hotpointwm64 pcb fault This topic has 3 replies, 3 voices, and was last updated 16 years, 8 months ago by lordhelpus. Viewing 4 posts - 1 through 4 (of 4 total) Author Posts July 20, 2009 at 5:14 pm #47211 lordhelpusParticipant 😀 the track from the door switch has blown. Can it be repaired? July 20, 2009 at 6:08 pm #292706 helo_75Participant is it a wm 64 or a wmA64? if its a wm64, the track will be on the timer ? worth a try, but youll need to change the lock, and check theres no hole in the door seal July 21, 2009 at 1:22 pm #292707 lordhelpusParticipant Re: hotpointwm64 pcb fault thanks for that helo. Its a customers machine. I changed the interlock first then spotted the blown track on the times board. Put a link across and it now works ok. Thanks again. Great site. July 21, 2009 at 3:22 pm #292708 iadomModerator Re: hotpointwm64 pcb fault lordhelpus wrote: Thanks again. Great site. Even better if you apply for trade access. 😉 Author Posts Viewing 4 posts - 1 through 4 (of 4 total) You must be logged in to reply to this topic. Log In Username: Password: Keep me signed in Log In
