Hotpoit AQXGF149M Fault code F05
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Hotpoit AQXGF149M Fault code F05
  • #64076
    LittleMan
    Hi customer just called with this fault code F05 can any one help please. Les
    #355977
    Re: Hotpoit AQXGF149M Fault code F05
    As a rule these fault codes are the same in most instances on Merloni gear.
    F05 is in the manual I sent you yesterday and the same error code is in the ‘Known Error’ codes thread in several posts.
    Usually a blocked pump. 😉
    #355978
    LittleMan
    Jim thanks for manual. Sorry about the fault code should have looked in the manual been one of those days and this call is over 20 miles away so wanted to be armed with right info thanks again Les
    #355979
    Take a pump with you just in case. 😉
    LittleMan
    Thanks again Les
