hotponit lft114 tripping rcd at end of cycle
Home Forums Public Support Forums Help And Support Dishwasher Help Forum hotponit lft114 tripping rcd at end of cycle
  • #78896
    snakeshack
    my hotpoint lft 114 runs normally until right at final drain then trips the main rcd on my power on restoration of power lights 2 & 4 from left are flashing,there are no visible leaks inside unit (I have watched it run an entire cycle with the cover off)any suggestions?
    #407302
    Re: hotponit lft114 tripping rcd at end of cycle
    Lights 2+4 relate to heater, one of the known weak points on Indesit dishwashers. 😥
    Heating element, connections, module, relay, pressure
    switch faults will all give that error message.
    If it is tripping then a megger across the heater to check the insulation reading would be the first thing to check.
