hi all..got a fault on the above washer..switch on..tumbles couple of times drain pump activates then the on off light flashes as does the mini load light..4th light down from top..i would imagine its an error code..anyone know what it is..cant find it in known errors section…took off n reconnected pcb to check..thanks 🙂
