Home › Forums › Public Support Forums › Help And Support › Washing Machine Help Forum › hotppoint wd 541/g stopped befrore spin cycle
- This topic has 7 replies, 2 voices, and was last updated 15 years, 7 months ago by
slyp98.
September 6, 2010 at 9:56 am #57032
slyp98
Participanthello all , this machine takes in water goes through the wash cycle and then stops before spin cycle , its still making noise though the lights flashing on display are wash enhance and the on/off , sounds like the pump is running , does this mean a blockage in the pump area or something more serious thanks
September 6, 2010 at 10:04 am #329584iadom
ModeratorRe: hotppoint wd 541/g stopped befrore spin cycle
Could you double check that model number please, not recognised in the official parts or tech info.
Also best to post the left hand flashing light by number from top down. 😉
September 6, 2010 at 10:09 am #329585slyp98
ParticipantRe: hotppoint wd 541/g stopped befrore spin cycle
cheers sorry model no is wf 541/g ser no. 707020360, left hand lights are from top no. 1 thanks again
September 6, 2010 at 10:20 am #329586iadom
Not good news, fault is F08, heater relay fault, might be a loose connection but is almost certainly a fault on the main PCB.
September 6, 2010 at 10:24 am #329587slyp98
thanks for that , will check it out and get back to you ,
September 6, 2010 at 10:28 am #329588iadom
If you use the forum search facillty and enter “Indesit AND eight AND flashes” in that exact format without the quotes you will get plenty of reading, most of it not very pleasant. 😥
September 7, 2010 at 6:36 pm #329589slyp98
cheers iadom ,
September 11, 2010 at 7:05 pm #329590slyp98
hi again , i took the connector blocks off the main board and plugged them back in again , the machine started the cycle and went into spin ok , the machine was around 5 years old so i told the customer it was probably the main board 120 quid or so to buy a new one , so they said they would ring hotpoint and see if they could get the call out covered by warranty , sure enough the hotpoint van was outside the door next day , dunno what it cost but im sure it was at least 120 quid !!
