Home › Forums › Public Support Forums › Help And Support › Vacuum Cleaner Help Forum › Hover Junior 1334 Problem
- This topic has 6 replies, 6 voices, and was last updated 20 years, 4 months ago by
beko1987.
December 10, 2005 at 8:52 pm #13970
beko1987
ParticipantHi Guys.
Stripped down and cleaned up a 1334 tonight, but during re-assembly I came across a wire I dont rememberseeing before. Not technically up on the lingo so I’ll have to newbie it! The wire comes from the big C shaped bit of metal that the motor shaft runs through, and the thin copper wire thats wound round this c shaped bit of metal sever hundred times also connects to this yellow wire. Any ideas where this wire connects to? Havent got any other Juniors in at the moment ot check this out.
Cheers
Sam
December 10, 2005 at 10:42 pm #157347Dave_Conway
ParticipantRe: Hover Junior 1334 Problem
The “C” shaped piece of metal is the field coil, the lead doubles up on the connection block on the outside of the motor with another lead but I’ve no idea which one now to be honest. I haven’t seen one for years 😕
The length may tell when reassembled of course as it will only reach one position 😉
December 11, 2005 at 12:39 am #157348Penguin45
The Goat will be in his element – he’s been doing these since he was 6! Bear with us ’til he answers…..
December 11, 2005 at 9:29 am #157349Martin
Good Lord!..This takes me back to the mid 60’s…when I was young and handsome 8)
Now even after all these years I can recall that one ‘Field Coil’ winding goes to one Carbon Brush terminal (the shorter of the 2) and the longer wire goes through the black casing (adjacent hole) round the side and through another hole alongside the terminal block and onto the terminal opposite the neutral lead (blue lead these days – was black in those days!)
ahhh such sweet memories….. 🙄
December 11, 2005 at 1:09 pm #157350Goatboy
Martin wrote:Good Lord!..This takes me back to the mid 60’s…when I was young and handsome 8)
I’ve gotta admit to not being 100{e5d1b7155a01ef1f3b9c9968eaba33524ee81600d00d4be2b4d93ac2e58cec2d} sure about it 😕 But one thing I am sure about, is that Martin doesn’t get things wrong 8)
However if you still have a problem, report back and I’ll investigate on Monday morning, when I’m back at Goatboy HQ.
Being in the time-warped town of Nelson, I’ve got loads of Juniors laying around 😀
PS. and of course, unplug the machine before attemping any repair.
December 22, 2005 at 12:52 am #157351electrofix
ModeratorRe: Hover Junior 1334 Problem
@ goatboy
if he has not unplugged the machine by now he would not be here to ask advise :rotl:
January 8, 2006 at 9:30 pm #157352beko1987
lo guys.
Forgot to come back to here! I sorted it, the cable screwed to one of the carbon brush brackets. She purrs now! Completely stripped the motor, took the bearings apart and removed 40 odd years of dirt!
