Home › Forums › Public Support Forums › Help And Support › Washing Machine Help Forum › Hover Vision HD Went Bang After E03, LCD Flickers & Broken
- This topic has 1 reply, 2 voices, and was last updated 12 years, 10 months ago by
DaiLafing.
May 26, 2013 at 12:19 am #75585
DaiLafing
ParticipantWhat Happened
I put in a big heavy carpet rug that probably shouldn’t have gone in, but it fit in so I did.
After pulling it out, it was a complete mess and I binned it. I also noticed that it was covered in a lacquer kind of gluey substance that was also present on the inside of the main glass door.
I did 2-3 empty full temperature washes hoping it would pass, in the end I scrubbed it off with a sponge because it stayed.
Then on the next wash of normal cloths, it seemed fine, but the cloths were covered in this lacquer type gluey stuff. So I put the same load back in a further 2-3 times but still it had this gluey stuff on it.Then a final time, I noticed that it filled up with water, then stopped with an error message and would not continue the wash. From memory, I think it was E03.
After turning off and back on again, and telling it to begin a new cycle, I would successfully drain out the water, and start again. I would leave it, and come back only to find that the same has happened again.
So this time I stayed with it, and shortly after beginning a cycle, I looked like it was struggling to turn the drum! Then to my surprise BANG! (And the dirt is gone! or not in this case!) There was a loud electrically sounding pop/bang from within, and the LCD started flickering the display.
I immediately turned off at the switch, and gave it a few moments.After 20-30 mins, I tried to turn on again, but it just loops the flickering LCD…
I’ve taken the back off, and the top lid, and as an absolute novice, nothing looks out of the ordinary. In face it all looks brand new inside…
I’d really like to fix this myself with your support because as we all know money is tight and were all feeling it, so please someone help me out.
May 26, 2013 at 8:37 am #395554Specialist01269
ParticipantRe: Hover Vision HD Went Bang After E03, LCD Flickers & Brok
Hi: Did you by any chance forget to clean out the pump & filter when you took the rug out ? E03 is a drain time error so it wasn’t pumping out properly. Unfortunately from what you say the control PCB may be blown now & probably the pump as well. The Gluey stuff that your talking about is probably the adhesive used to bond rugs, it melted in the Hot water.
