how about this one ?
  • #48513
    delta01
    went to washer two yrs old cust complained of strange noise ,also tripped rcd , checked usual things pump , motor , earth leakage, spider/bearings etc ran machine got strange twiching motor and clanking noise , i reset the program and ran it again it seemed ok so i left thinking i will get a recall . of course i did.
    on returning i stumbled accross the fault when the machine went dead can you guess the fault ?
    #296782
    What machine it is might help. 😉
    bazza500
    Re: how about this one ?
    The machine was made of chocolate. The customer had put it on a 60oC wash and it had melted? :con:
    #296784
    delta01
    its a haeir not a cadburys
    #296785
    They melt down just as easy. 😉
    Helo might know.
    robbra
    Can’t believe a Haier lasted 2 years 😉
    #296787
    One for the record books…….
    #296788
    Blocked filter?
    Mike.
    #296789
    helo_75
    duff motor
    it WILL have had at least one fitted
    #296790
    delta01
    i thought at first it was a duff motor , the fault was simply a duff/intermittent plug socket , it was causing a fluctuating supply , i would not have found it if it had not gone dead , i moved the plug about and it came back on, i then tried it on another socket and it was fine , i cant believe the strange affect and noises it produced though
