how and have i been lucky ?
Viewing 15 posts - 1 through 15 (of 17 total)
  • #89707
    adv
    😥 hi silly i know but . was at a beko dishwasher lam 8301. was at this tonight . been a few times and doing my nut , girl saying not washes dishes wright . so was still plugged in . 😡 but had door open and on off switch off , so decided to put my hand in an touch the heater . to see if was hot . got a right shock off it which tripped rcd , oouch . . was being stupid i know , but how can there be juice there when door open and on /off switch off 😳 and am i lucky to be alive ❓
    #442253
    Re: how and have i been lucky ?
    So you have never seen a faulty on/off switch before. Any on/off switch to me just means a piece of plastic is in one position as opposed to another.
    #442254
    adv
    door was opened and to be extra safe :death: . i put on /off switch off
    #442255
    If I can’t see a plug that is not pulled from the socket then I wouldn’t trust an on/off switch without passing my mains sniffer over it.
    #442256
    No earth connection is the more likely reason.
    #442257
    adv
    how that it tripped rcd ? no earth on heater do you mean ?
    #442258
    I think we’ve all had a belt one time or several.
    As the Pink Floyd album title stated all down to a, momentary lapse of reason.
    Just lucky I guess that the RCD saved you and sometimes it’s not really your fault, most times I expect it just comes down to making assumptions that prove to be false.
    Wouldn’t worry about it too much though, gives the heart a jolt and reminds you not to be so damned stupid. 😉
    adv
    😥 well wont be doing it again . . just mift how there was any [power going to heater with door and on/off off :rolls:
    #442260
    I walked into a house one day, brand new build, warranty call on a Candy integrated washer.
    Easy job, module fried and knew that before I walked in, with said module.
    Now being as I knew these machines like the back of my hand, all I needed to do was draw it out, tip it back, reach in and pop the old module out, bang a new one in…
    Two minute job.
    Me being me, switched off the power on the isolation wall switch. Just so as I didn’t get a belt you understand.
    Reached in, grabbed the module and blam, next words out my most were along the lines of “Oh you mutha******* ******* of hell”, RCD pops, house goes dark.
    Woman walks through and says, “sorry I forgot to tell you that the switch doesn’t cut the power off, hope that’s ok?”
    No it’s ********** not ok you stupid ******. I thought, didn’t say.
    Easy job, yeah okay.
    A close relative is a very, very good sparky and he scares the bejesus out me working on live stuff but he’s relaxed about it, no idea why as some of the stuff he works on would probably belt you hard enough to put you in orbit. But his attitude is, so long as you tick the right H&S boxes all is well, if you’re dumb and make a mistake that’s fine you won’t do it again. If you’re really plain bloody stupid and make a mistake that kills you you won’t make the mistake again either. So win, win.
    The upshot being, stupid people or those without a clue shouldn’t be working with electricity.
    But his take is, if you’re on an RCD protected circuit the chances of you coming to serious harm are so remote as makes no odds. You’ll get a jolt, a bloody good fright but killed, no unless you’ve a pre-existing condition that would likely kill you if you touched the wrong terminals on a decent battery.
    If you don’t check it’s on a protected circuit, your bad.
    If you don’t check and you do something dumb, guess what?
    If you take a punt and it all goes wrong, guess what?
    I tend to check now. Getting zapped may well give the old ticker a jolt and get the juices flowing but honestly, I can live without the trauma.
    LothianDomestics
    Spectator
    If you have a neutral fault or a switch cuts the neutral feed rather than live, then it’s still going to be getting a live feed to it. Door open, on/off switch is irrelevant in these cases as when you touch it, you are acting as the neutral.
    #442262
    adv
    :rolls: was thinking that . like lights always a live and just switches the neutral
    #442263
    never assume unless you have checked.
    had a house cross polarity from the meter years ago. that mean every circuit was protected by a 60 amp fuse as all the fuses were in the neutral
    really lucky they never had a fire
    adv
    :fire: :death:
    #442265
    EFS
    Long time ago before the age of RCDs I had a call where the mains lead to the washer had been extended using a three pin in line rubber connector which I unplugged and got the shock of my life.
    The customer had wired the live/neutral into the male pins.
    Lesson learned.
    Steve.
    #442266
    adv wrote::rolls: was thinking that . like lights always a live and just switches the neutral
    We’ve all punted our thoughts as to what potentially what was the reason. Do tell us what you found in the end?
