How do I change the door seal on a Hoover Optima
Home Forums Public Support Forums Help And Support Fridge And Freezer Forum How do I change the door seal on a Hoover Optima
  • #60636
    chunk79
    We have inherited a Hoover Optima Model Number RD4B001, however the seal was cracked and broken. We have ordered a replacement but it seems impossible to get the lip on the seal in behind the plastic lining at all – there aren’t any screws – is it even possible to change the seal on this model?
    Thanks in advance
    Tim
    #343035
    spimps
    Re: How do I change the door seal on a Hoover Optima
    If there aren’t any screws it’s a complete door.
    Not heard of anyone succesfully changing a moulded in one.
    You could if it’s only cracked fill up the seal in the damaged area with white bath sealant,will harden over a couple of days and usually does the trick
    #343036
    chunk79
    Thanks spimps
    the cracking was pretty bad and we had taken the old seal off already unfortunately. Will try and silicone the seal in or something – seems strange that they would sell a part that can’t be fitted but I guess that how they make their money?
    T
    #343037
    BobHope
    the seal can be fitted it just needs to be prised open a little on the liner to get it to fit, its fiddly but it willl fit, hoover have a tool to do it but its not realy needed.
    Bob.
    #343038
    chunk79
    Yeah we seem to have got it on with some prising with a knife – did a fair bit of cosmetic damage on the way though and we can’t quite get the bottom edge in fully but it is working for the moment.
    T
