Re: How do I know whether an Electrolux washer has a welded
Thanks, that was quick :). Not to mention a lot clearer than the responses I’ve received from all the salesmen I’ve asked, all of them basically said “huh?”.
Am I right in assuming that generally the high-end Electrolux machines have split tubs whereas the low-end ones have welded tubs? Or is there a risk that models in all of the range may have the welded ones now? I initially considered buying the cheaper EWF167320 (which was “Made in EU” and not “Made in Italy”), but I assumed that the probability of this machine having a welded tub was greater than the more high-end EWF168540.
