How do I remove motor from Bosch WF02864GB Home › Forums › Public Support Forums › Help And Support › Washing Machine Help Forum › How do I remove motor from Bosch WF02864GB This topic has 3 replies, 3 voices, and was last updated 18 years, 9 months ago by Winco. Viewing 4 posts - 1 through 4 (of 4 total) Author Posts August 4, 2007 at 3:18 pm #29511 WincoParticipant Hi, I have had this Bosch Maxxis for about 5 years and sure enough it has stopped spinning. I have read the forum and it looks like I need to change the brushes. However I have removed the two bolts that appear to hold the motor, and removed the loom to the motor but it is stuck firm. Any suggestions please? August 4, 2007 at 4:28 pm #223467 Penguin45Participant Re: How do I remove motor from Bosch WF02864GB Big flat bladed screwdriver and a bit of leverage by the mounting lugs is the usual way. Power off, of course. Penguin45. August 4, 2007 at 10:52 pm #223468 WincoParticipant Re: How do I remove motor from Bosch WF02864GB Fantastic, finally worked but they were really tight. I swapped the brushes round to prove that was the problem and sure enough it has started spin again. Now where can I get the replacement brushes from. Thanks again everyone on this site, it has saved me an expensive bill or more likely throwing away a perfectly good machine before I needed to. August 4, 2007 at 10:58 pm #223469 iadomModerator Re: How do I remove motor from Bosch WF02864GB Winco wrote:Now where can I get the replacement brushes from. http://tinyurl.com/3dq3oy 😉 Whatever you do, do not run the machine with worn brushes, a sure fire way to blow some expensive electronics. Jim. Author Posts Viewing 4 posts - 1 through 4 (of 4 total) You must be logged in to reply to this topic. Log In Username: Password: Keep me signed in Log In
