How easy is it to get inside my Hotpoint DWF40
Home Forums Public Support Forums Help And Support Dishwasher Help Forum How easy is it to get inside my Hotpoint DWF40
  • #14156
    bikerboy
    I only ask as that, for some unknown reason, I am unable to download the servive manual at this point.
    #158374
    Dave_Conway
    Re: How easy is it to get inside my Hotpoint DWF40
    You won’t be able to download the service manual from anywhere I’m afraid, only the user manual.
    We aren’t able to give blow by blow details for legal reasons, which part of the dishwasher are you trying to gain access to ?
    #158375
    bikerboy
    Hi dave,
    I would like to trace the wiring from where the cable enters at the base. My guess from reading this forum, and from the fact that I removed one of the side panels yesterday to reveal absolutely nothing, is that I may need access to the bottom.
    We have had problems with mice in the past, and it is possible that one has got inside and is causing the problem.
    PS. I work with electronics so know what precautions to take.
    Thanks DD
    #158376
    Access to any area of a DWF40 will require the removal of one or more panels with a pozidrive screwdriver…that’s it!
    Caution is required when dealing with suspect Rodent damage as a small mouse can access all areas of the machine without a screwdriver. It therefore will be necessary to inspect all areas for chewed pvc cables, rubber hoses and insulation materials within. 🙁
    #158377
    Just a small point bikerboy, it helps to keep the forum tidy if you do not make multiple posts on the same subject.
    http://www.ukwhitegoods.co.uk/modules.p … ght=#63220
