How many machines have been written off
Home Forums General Trade Forum How many machines have been written off
  • #89263
    Simon46
    Just a thought before engineers googled faults before 680uf indesit caps, bosch fridge freezer short out thermistor to run in emergency mode,bit100 cap replacement etc, before pcb tricks and tips came out how many do you think you have written off due to an expensive pcb replacement?
    #440850
    Re: How many machines have been written off
    lots i would think. depends on your level of knowledge. i am lucky as I have a good working knowledge of electronics although more info on progamming chips would be good if i can find time to do the research
    Simon46 wrote:how many do you think you have written off due to an expensive pcb replacement?
    Almost an impossible question to answer other than chances are the vast majority of machines wanting expensive replacement boards are scrapped. At a guess I’d say 95{e5d1b7155a01ef1f3b9c9968eaba33524ee81600d00d4be2b4d93ac2e58cec2d}…??
    #440852
    stratfordgirl
    I’ve never repaired a board, but replaced hundreds. The cost is often not prohibitive, particularly for newer, mid-range machines. I guess it depends a lot on your customer base.
    #440853
    twicknix
    I’ve written loads off until I discovered EMW and QER. Maybe with this whole Brexit saga, customers might be more willing to have it fixed than replacing appliance since the new appliances are beginning to be pricey.
    #440854
    Simon46
    Could be good for us!
