Home › Forums › General Trade Forum › How many water valves can be stripped down these days?
- This topic has 9 replies, 7 voices, and was last updated 18 years, 8 months ago by
andy_art_trigg.
July 31, 2007 at 2:49 pm #29412
andy_art_trigg
ParticipantI’m looking at a safety product that involves stripping down the water valve in a washing machine to fit a. I’ve just realised that some water valves are sealed and cannot be stripped down. How widespread is this? How many washing machines have the old-style water valve with four screws holding the two halves together?
July 31, 2007 at 4:59 pm #223028iadom
ModeratorRe: How many water valves can be stripped down these days?
andy_art_trigg wrote:I’m looking at a safety product that involves stripping down the water valve in a washing machine to fit a.
Come on Andy, don’t keep us in suspense, to fit a ????????????.
I haven’t seen a valve with four screws in for years, other than in very old machines. It is possible to unscrew some of the later valves but others are that tight or glued and are impossible to open.
July 31, 2007 at 5:29 pm #223029kwatt
KeymasterRe: How many water valves can be stripped down these days?
I can’t recall the last time I saw a valve that could be stripped down!
Any I’ve seen recently have all been sealed throw-away jobs. 😕
July 31, 2007 at 5:41 pm #223030iadom
Just for you Ken, this is a brand new Hotpoint 161387 I have just dissected. I use a pair of long nosed pliers to unscrew the stem, sometimes they are very difficult to turn but I succeed 75{e5d1b7155a01ef1f3b9c9968eaba33524ee81600d00d4be2b4d93ac2e58cec2d} of the time.
I only do it if I come across an unusual shaped valve that is leaking and that uses the same valve stem.
July 31, 2007 at 9:56 pm #223031electrofix
go to a well used glasswasher on occasions in a local pub weird has awkward placed valve but diaphram from old hot valves fits a treat dont know where i would b if i could not swop it
August 1, 2007 at 11:50 am #223032Goatboy
ParticipantRe: How many water valves can be stripped down these days?
The coils will normally just pop off, but every manufactuer seems to have a different plug arrangement on the coil 😕
August 1, 2007 at 1:10 pm #223033andy_art_trigg
I’ve had quite a few where I couldn’t even get the coil off and some where the coil comes off but I couldn’t unscrew the stem without damaging it.
August 1, 2007 at 5:34 pm #223034robbra
Why Bother?
August 1, 2007 at 7:30 pm #223035andy_art_trigg
I’m looking at a product similar to a Bosch aqua stop hose. To fit it you have to remove the little plunger inside the water valve. Once fitted it replaces the valve with one right at the beginning of the hose so when the valve is off there’s no pressure in the hose so it can’t burst.
It also eliminates most of the water hammer associated with the valve shutting off which can be loud in some homes. The idea is it can be fitted to any washing machine.
August 1, 2007 at 8:31 pm #223036Firestarter
ParticipantI bothered today as the diafram in a aquastop valve had burst on an old siemens dishwasher. The customer didn’t want to run to the expense of a complete hose kit, so I removed the diafram from a uni single valve. I must say the new valve presented a chalenge as it was glued together!
Gordy
