Re: How to Change Belt on Hotpoint VTD00?
Yes, on these it is usually easiest to remove the screws that secure the back, pull the drum back enough to create a big enough gap at the front to slip the belt over then position the belt on the witness mark where the old belt ran. I find you can improvise the special tool using some stiff tubing such as steel electrical conduit. Put the tube between belt and drum, poke the end of the tube over the end of the motor spindle, lever the tube down so it’s in line with the spindle then work the belt along to the end of the tube. Withdraw the tube, holding the belt so it drops onto the vee grooves of the spindle.
