How to change spark generator on SMEG P705 hob
Home Forums Public Support Forums Help And Support Cooker And Oven Forum How to change spark generator on SMEG P705 hob
  • #95564
    Douglees
    My SMEG P705 hob has stopped generating ignition sparks. I am assuming it will be a faulty generator module but have no idea how to get to it, anyone help?
    #460759
    to get at the spark generator the hob has to be disconnected from the gas supply and removed from the work surface.
    As you can imagine, since this job will require gas pipes to be worked on it should only be attempted by a qualified gas safe engineer
    have you checked the plug?
