How to choose an electric hob??
Home Forums Public Support Forums Help And Support Cooker And Oven Forum How to choose an electric hob??
  • #26603
    noisette
    Hello, I’m a newbie..be gentle 😀
    We’re planning a kitchen from scratch but as we won’t have mains gas, after cooking with gas for the last 30 years, I need to get up to speed on the current choices for electric hobs. Could some kind person tell me the pros & cons of ceramic, halogen & induction hobs, please? We’ll be using Le Creuset and heavy-based stainless steel pans.
    Also, is it still the case that a built-in oven and hob both need dedicated electricity supplies?
    Many thanks in advance…..
    N
    #210776
    helo_75
    Re: How to choose an electric hob??
    dependant on the oven or hob you buy, they could just plug in
    that is of course, whether its single or double oven….
    now, and this is very important
    avoid anything built buy merloni, that includes hotpoint, creda and indesit
    get some bosch/neff stuff, and ull have little problems
    #210777
    hotpnt
    hi helo, just wondered why you dont like the creda build stuff?? these are still well built cookers, hobs & ovens
    #210778
    helo_75
    yet rubbish
    most of its rebadged indesit
    id rather sjhave my head with a rusty cheese grater
    im sick of changing elements… and now the stats are so bad the stats are goin with em
    i got a bosch oven at home and its ace
    #210779
    Hi Noisette,
    I’ve not personally tested induction but I’m reliably informed that it is as good, perhaps even better, than gas. If your pots and pans can cope with induction that would probably be your best bet.
    In your circumstance, where you haven’t got mains gas, getting LPG installed and serviced cooker-wise is a nightmare as there aren’t enough people around to do it and, when you do get someone, it will likely prove expensive.
    Ceramic is okay, but not as good as induction. Halogen I have used and didn’t like it, I didn’t think that there was any real advantage over normal ceramic in use.
    You may need two supplies, that depends on the appliances that you choose and specifically, the amount of power that they draw. But I always recommend putting both on their own switched supply so that, if one does fail, at least you can still have the use of the other.
    Hope that helps.
    noisette
    Thank you all very much…we’ve got a much clearer idea now of what to look for. 🙂
    #210781
    wsts
    Why not have a lpg hob ?
    Then you wont have to change from gas.
