How to Clean Dishwasher
Home Forums Public Support Forums Help And Support Dishwasher Help Forum How to Clean Dishwasher
Viewing 15 posts - 1 through 15 (of 15 total)
  • #20591
    5853hollyb
    Hello,
    Our Whirlpool ADG722 office dishwasher is starting to smell, it still cleans ok, but although the mugs are clean, they have a bit of a nasty whiff. The dishwasher itself is bad enough to make you gag
    How do you clean it? What products can be used to clean it and where do you put salt? as it’s been in the office for about five years and no one has ever cleaned or put salt in it, so i’m imagining that could be something to do with it…don’t blame me, i’m new!! 😉
    Thank you!!
    #187616
    Re: How to Clean Dishwasher
    Plenty of useful info here. http://tinyurl.com/ovvw5
    The salt compartment is fairly obvious on most dishwashers. Usually a large round cover in the base that you unscrew to fill with special dishwasher salt. A must do in hard water areas.
    madrat
    😯 how has it been washing without salt?
    To clean it select a hot program without a pre-wash. Start the dishwasher (with salt) and what to see if any water drains out. when you hear it start to fill stop and open the door. add half a cup of white vinager and re start the machine. If its really bad you might need to do it twice, you can bye cleaners for dishwashers but the white vinager is just as good and a lot cheeper. 🙂 Also make sure the water jets in the spray arms are clear.
    #187618
    madrat wrote:😯 how has it been washing without salt?
    There are many hundreds of dishwahers in this ‘ultra soft water’ part of the country that have worked perfectly for many years without salt of any kind.
    #187619
    madrat
    Thought Lancashire had hard water? Or is that Yourkshire?
    #187620
    madrat wrote:Thought Lancashire had hard water? Or is that Yourkshire?
    Theres nowt really hard in Yorkshire, only skulls 😛
    #187621
    madrat
    😆 now now
    We are all semi hard in the midlands 😯 😛
    #187622
    iadom wrote:Theres nowt really hard in Yorkshire, only skulls
    Tha’s feeling lucky then, Iadom? 😀 😀
    Ok – do you have hard water or not? Take the lid off the office kettle and take a look – if it’s scaled up, the water has chalk in it – if it doesn’t the water is probably pretty soft. However, you should top up (and keep topped up) the salt chamber, even allowing for low usage. There are proprietary dishwasher cleaners available which can be dropped in the basket and will operate when temperature is reached, alternately, a Jif lemon emptied into the the machine when you hear the dispenser go “Clunk” is also extremely effective.
    Vinegar is acetic acid and has different properties when compared to citric acid (an active ingredient in most cleaning products). It also lacks the nice odour at the end 😀 .
    You may have to repeat the process several times if the machine has become particularly smelly, but it will come clean. Eventually.
    madrat
    Vinager is recomended By Kim and Aggie and it dose work belive me.
    #187624
    Or even better just buy some Finish dishwasher cleaner and do the job right without all the fuss. 😉
    madrat
    If its bad then yes but the vinager used every couple of months stops the problem and its a lot cheeper.
    #187626
    Trilobite
    I wish some posters (who shall remain nameless) would take greater care over their spelling and punctuation!
    #187627
    madrat
    Befor you have a moan about peoples spelling remember ther is such a thing as dislexsic!
    #187628
    Point of order chaps – we don’t do spelling, grammar, or anything else. We do do abuse, swearing and personal insults. All are welcome to post, whatever their opinions, all are welcome to reply. Don’t make it personal, or this group of posts may not be here in the morning.
    Penguin45,
    Moderator.
    #187629
    madrat
    Sorry I just wish people would give us a brake. Its hard enough as it is.
