How to connect condensor dryer to water supply?
Home Forums Public Support Forums Help And Support Tumble Dryer Help Forum How to connect condensor dryer to water supply?
  • #98393
    wmda99
    I have a Beko DTGC7000W condensor dryer, and I think it would make my life a bit easier if I connected it to the waste water supply, so I don’t have to empty/clean the water container.
    It came with a coiled pipe but no instructions on how to connect.
    Any ideas on how I can do this?
    Do I need a plumber?
    Any advice gratefully appreciated!
    #472203
    it should show you how to fit it to the machine after that you need to connect it to the drain and it depends on the configuration of your plumbing
    and yes you may need a plumber unless your washing machine is connected to a stanchion pipe
