Hi all
Ive got the above w/d which is stuck in e90, I have cleaned and tightend both ends of the blue link wire between boards no change. I have both boards out and am checking them and wires to them but all looks ok.
Can someone tell me how to start diag test on this machine to see if that helps ?
Thank you
Paul
Just been to this The real fault code is e94 (config)? can I reset the config on this modual, do I need any special programer to do it? or should I get a new board (can I config the new one?)
Ta
Paul
