How to drain exxcel dishwasher after leak under it
Home Forums Public Support Forums Help And Support Dishwasher Help Forum How to drain exxcel dishwasher after leak under it
  • #69339
    angel50
    I seem to have a very slow leak under my Bosch Exxcel dishwasher, as well as a fast leak at the inlet hose after moving it! 🙁 when we replaced our kitchen floor. So I stopped it midcycle. Do you know the setting I need to put it on to drain the water left in the bottom of it as looking under the salt cap I see its full of water and also can I run it with the cold supply tap closed as I don’t want the back to leak more whilst I do it? In the instructions it says ECo cycle for 4 mins – just don’t want to make matters worse!
    #374457
    angel50
    Re: How to drain exxcel dishwasher after leak under it
    Thanks Allsorts just seen your reply. Just trying to stop it leaking on my new floor before I can get an engineer to it. 🙁
    #374458
    Turn it on with the door open then press the two buttons marked ‘RESET’ then shut the door. Your machine will then drain out and turn off….easy!
    #374459
    angel50
    Thanks very much for your help. I don’t have two buttons marked reset on it but there is a Reset 3 sec mark on the dial.Will this do the same thing? Its model type is S9N51B.
    #374460
    Yes!
