Home › Forums › Public Support Forums › Help And Support › Cooker And Oven Forum › how to fix low flame problem with the owen
- This topic has 9 replies, 4 voices, and was last updated 9 years, 5 months ago by
goodlv.
October 27, 2016 at 12:58 pm #89701
goodlv
ParticipantHi there,
My oven seems to give a low flame. Even when I set up to max gas mark it’s low and it takes ages to cook something.
Owen model – esteem si500
any ideas what could be faulty or fixed?
Regards
October 27, 2016 at 2:19 pm #442227Martin
ParticipantRe: how to fix low flame problem with the owen
goodlv wrote:Owen model – esteem si500
Owen? There’s a NewWorld si500? Owen doesn’t Google up any answers.
Low flame could be blocked jet, FSD playing up or the gas tap itself at fault. In any event it is NOT a recommended DIY fix but rather you should contact your local Gas Safe repairer.
October 27, 2016 at 2:35 pm #442228don
ModeratorRe: how to fix low flame problem with the owen
I reckon the OP was using a small keypad like a phone or suchlike as the word “owen” in the title and “owen ” in the post should read oven!!
DonNovember 3, 2016 at 3:55 pm #442229goodlv
Yes, obviously oven, not the owen..
So without the specialist, I can’t run any checks before I call experienced guy in ?
November 3, 2016 at 4:15 pm #442230Martin
goodlv wrote:So without the specialist, I can’t run any checks before I call experienced guy in ?
I gave you 3 possibles in my previous post. Chances are it’s one of them. 😉
November 4, 2016 at 4:13 pm #442231goodlv
With safety we can approach and do tests I assume, it is not my first time working with the tools.
here is the picture of the jet – https://s3.postimg.org/jdq8h6ocx/20161104_160349.jpg and
https://s12.postimg.org/cv1oqlhzx/20161104_160354.jpg
the only thing I can do is clean that , anything else?November 4, 2016 at 5:23 pm #442232Martin
goodlv wrote:the only thing I can do is clean that , anything else?
Actually no, that won’t help any as that is the ‘burner’ unit and not the gas jet that supplies the fuel. The only thing you can do to the burner unit is regulate the air flow to establish the correct ‘gas to air ratio’ to maintain an even blue coloured flame. Chances are that has already been pre-set anyway.
In the interests of your safety I am not prepaired to elaborate further nor am I ‘Gas Safe’ qualified. There are no regulations in this country to prevent you from tampering with your own oven. And your questioning already suggests to me and others that you haven’t a clue how to rectify the problem. Again I urge you to seek expert help from a fully qualified person who could fix it for you and provide the official documentation to show that the full safety checks and tests have been implimented.
November 4, 2016 at 6:59 pm #442233Lawrence
It’s not a fault you can fix yourself , you require an engineer
November 4, 2016 at 10:36 pm #442234goodlv
Where I can find these specialists ? gumtree ?
November 4, 2016 at 10:45 pm #442235Lawrence
Look on the engineer search on this site
