how to get the back off a Zanussi FJ1296
Home Forums Public Support Forums Help And Support Washing Machine Help Forum how to get the back off a Zanussi FJ1296
  • #12148
    Algee
    have a Zanussi FJ1296 washing machine (type p6297236, product no. 914787502/01) which needs a new bearing. I thought I’d have a go and I’ve bought the kit – but have fallen at the first hurdle as for some reason I can’t get the split outer casing from the back of the machine to separate! I’ve taken the screws out at the top and at the back etc and put the machine onto its front but there seems to be a fastener on the inside near to the bottom. I’ve tried levering the bottom edge of the casing down but it doesn’t budge.
    #148090
    Re: how to get the back off a Zanussi FJ1296
    Remove the two little plugs at the bottom of the rear casing just behind the split line and see what you find 😀 .
    Good luck, power off.
    Algee
    Thanks Penguin. I have done the job but it took over two hours to get to the bearings! I see now why everyone says its a long haul.
    Anyway this is a great site – be seeing you again!
