Re: How to identify the model of my fridge/freezer..
Unfortunately it probably will be a problem 😕
Like most refrigeration manufacturers they have a plethora of models all with different styles/fittings etc. It’s highly likely you can’t replace the seal as an individual item (carefully ‘peel back’ part of the seal to look underneath it, if you can see screws holding the liner to the outer door then you’re in luck) If the seal can’t be replaced then you’re looking at a whole new door and the handle will be part of the styling which will be unique to your model.
IMO your only chance, and slim it is, is to find an engineer who’s seen a lot of these to see if he could identify it for you.
You could try posting some clear pics on here, you never know someone may be able to identify it but i wouldn’t hold much hope i’m afraid. 😕
