How to Know when Dampers Need Changing?
Home Forums Public Support Forums Help And Support Washing Machine Help Forum How to Know when Dampers Need Changing?
  • #60997
    pearce_jj
    Hi All
    Interested in the above. Not because I think there is a problem, just interested to know how I’d know if there was!
    Cheers
    #344502
    Re: How to Know when Dampers Need Changing?
    The easiest way is like the old timers way of checking car shock absorbers, they used to push down hard on the car wing to check for bounce.
    Remove the plug, take off the top and press sharply down on the drum, if there is good resistance and the drum returns to its original position without any ‘bounce’ and there is no rough grating,squeaking noise then the dampers will be OK.
    If the drum is easily pushed down and then bounces several times the suspension is goosed.
    #344503
    pearce_jj
    Thanks very much indeed 🙂
