How to mend a Hotpoint wma ‘door light flashing’ PCB
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries How to mend a Hotpoint wma ‘door light flashing’ PCB
  • #52454
    neilsukwg
    Now that pcb repairs has its own sticky
    I was wondering if anyone had cracked the code yet on mending the flashing light of death on these older wma boards
    A visual of the board has yielded no clues..
    Anyone had any luck repairing one?
    #311842
    Re: How to mend a Hotpoint wma ‘door light flashing’ PC
    Usually there are burnt copper strips so you just need to solder in wire links. You could check continuity between the interlock plug and the corresponding plug on the module.
    #311843
    lasty
    neilsukwg wrote:Now that pcb repairs has its own sticky
    A visual of the board has yielded no clues…
    No such luck yet ……
    Considering sending a board to EWM (?) and see what they change 😯
    SSHHHHHH ……..!
    #311844
    EMW… Tony is an active UKW member.
    recall
    usualy small triac located btm r.h. corner on the track side. not sure of prt number though. unless your dab hand with a soldering iron i think tony is best bet.
    #311846
    lasty
    No such luck yet ……
    SSHHHHHH ……..!
    Ooops-it`s not a case of what you know , who you know !!
    Sorry – i`ll press on with the experimenting
    #311847
    Allsorts
    recall wrote:usualy small triac located btm r.h. corner on the track side. not sure of prt number though. unless your dab hand with a soldering iron i think tony is best bet.
    I’ve had a few that have had the chip blown, and I’ve changed the chip quite tidily on some of the boards but something else must go at the same time because the replacement chip alone has never repaired a board for me.
    George
    #311848
    I had a go at one with blown lock triac and two small smd’s close to it but it was wasted effort, had to get one from the Edinburgh Woollen Mill in the end.
    No, sorry, it was E.M.W.
    Mike.
